Originally Posted By moparjim79
Did you put poly mounts in the trans yoke as well?
I am not sure what you are referring to. You mean the trans mount? if so, it is just a regular mount, not a poly.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
