when the seal ends are at 6 & 12, and the retainer cap fits correctly dry, tighten the retainer bolts then fill side cavities with rtv. correct ?
That is correct. J.Rob
thank you ! i'm glad to see , finally, a GOOD fix for this very common problem. i'm sorry it took you an inordinate amount of time, grief, and expense to sort this out. thumbs up to you !
