Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail.
