Delrin bushings are some of the easiest things to machine. That stuff turns like a lathe operator's dream. If he can't supply then, I can probably remove the sleeves from yours and pop delrin bushings in without too much fuss.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
