Quote: You guys can argue this to death but I will say this, again, I am NOT a racer of any kind, there is absolutely NO WAY you could tune a stock suspension and get the level of handling I got on my 69 Dart when I installed a Hotchkiss TVS ! M
Actually, that's what you did. The Hotchkis setup is based on the stock setup.
Thank you.
Hotchkis is stock based. RMS and XV are not.
It may be based on stock but it is wayyy different! Upper arms have a different angle, rear springs are different, frame connectors were NEVER even considered from the factory so I have to respectfully disagree . I do agree on the RMS being all or none, I do have one of those in my GTX as I mentioned.
