Well now I am really getting frustrated as it will not start yet. I have replaced the ecu with chrome mopar one, the resistor with MSD .80, and the fuel pump with a 150 gph mechanical pump. Still did not start. I checked the coin for spark, it has a big spark and about knocked me on my butt as it arched across the metal and came back and hit me! then I pulled a plug wire to make sure it had spark at the plug. Yes it had good spark there. Poured a little gas in the center carb and it fired off.
My only other thoughts are the fuel filter or the sock inside the tank?? I am going to pull the filter tomorrow it is brand new "date code" correct metal one. Has anyone had any problems with those??
now you know whythe "shock" people back to life. I'm guessing you have a blockage someplace. Run it straight from the can and see what happens. I had an issue w/ a blue gasket covering a tiny passage in the primary that gave me all kinds of fits.
