I have a t56 behind a small block with a quick time bell. The quicktime bell is not really machined like a normal bell housing that centers off of the input shaft retainer where you are indexing it off of. Mine was cut real ruff around the circle. I don't really know if that is truely the center. I could not come up witha good way of doing it and ended up just bolting it togeather.
