Lee whats the back spacing on your wheels... I dont
know your front end but from testing and my own work
I have seen that if the wheel/tire centerline is out
past the centerline of the ball joint the braking
causes flex... the farther out it is the greater leverage
arm it has... it only shows up under braking but once
it starts it gets bad and it tears up parts
Hi Mike
My wheels have 2.25 inch back spacing. If you are talking about scrub angle, we have tried several different thing to help the scrub angle and it seemed to have little effect. Rob from LRT and I have been working on the brake shake problem on my car. We have fixed it. No more brake shake. I have raced my car all summer with no brake shake. We changed a couple things and eliminated the brake shake. We are now trying to get it to brake shake to find out exactly what fixed it. Sort of a A-B-A test. We have a pretty good idea, but want to be sure. We also fixed the tires toeing in when backing up problem. I just got a set of wheels with the other back spacing to try to see if that has any effect.
Lee
What corrected the toe in problem when backing up? We are having the same issue with ours.
