Quote: Old drivetrain weighed 670 lbs. This is a 360 with iron heads and a cast iron four speed.
Andy,
I have never understood what good is does to put the PCV that close to a breather. The PCV can not pull any crankcase vacuum because the airflow from the breather to the PCV has very little flow resistance. Does the filter for the breather also have a check valve that only allows outflow of air?
