Quote: ... Are you asking how much the 427 engine that we're building will cost? My spreadsheet says it is adding up to $15,000 retail.
Gasp, Gasp... I'm out.
Whether I had the money or not, I can't justify that until I've spent a similar amount on the chassis to utilize that power. And I think to do that a roll cage and mini tubs would be in that mix.
At that point I'd personally rather build a racecar legal for VARA vintage racing. Same money, more fun.
Also, is that $15K not including assembly labor. Like just parts and machining in the $15K number.
