This statement made by superbirdtom .I what I refered to early on .You had to remove a bracket .From old nose to N.O.S. one replacing it
superbirdtom
Full Member
Offline
Re: N.O.S. Superbird Nose Cone Tech VS/ Repos
« Reply #1 on: Yesterday at 11:06:07 PM » Quote
just to add to all the previous well coverd posts. I believe the difference is that the replacement cones if you ordered one from the dealer back in the day they didn't come with the piece that mmounts the top side of the cone to the rad support. you had to take it off the damaged one ant reweld it onto the replacement one.
And I believe that the ones that came on the cars delivered some had wiring holders that are tacked to the interior of the cone to hold the hoses and h-light wires . I believe i have seen them with and without them as a difference between stock and repop. the steel repops look damn good in my opinion.
