How a B3 kit impacts the valve lift is dependent upon the rocker arm's dimensions & geometry. This pic shows a T&D on the left and a Hughes on the right. If you look at the respective locations & angles of the lash adjuster screws, you may understand how moving the rocker arm up and / or away from the original pedestal location can change the lift curve more on some rockers than others. It's one of those factors that you only know for sure by plotting the lift curves with and without the relocation kit in place.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
