Finally, we tried a custom B3 T&D setup using shorter 1.45"-fulcrum 1.60 rockers set up for .650" net lift. The pushrod geometry and sweep pattern were basically "nuts on" w/ Jim Miller's Mid-Lift rocker arm geometry design, but the actual lift curve wasn't significantly different than the Hughes 1.60 setup w/o the B3 relocation kit, so I kept what I had as what I was hoping for was a net increase in lift to go along w' the improved geometry.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
