The leaf cars I set up, I use the absolute stiffest front segment that I can buy and then use the rear that makes the car sit where I want it. Put good shocks on it and you are done.
On the wheelstand issue.........that's setup if you are having issues. If it wheelstands on slicks, you need more wheelspeed or less bite. If it wheelstands on radials, likely needs more front percentage and some better power management
