at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar
The spring is there to hold up the car.. you dont want 2 opposing forces on the spring.. the shock controls rise .. you might have to move the wheelie bars up higher
