I would try going to your upper hole and tighter on the extension and compression. All adjustments on shocks are made from full tight, so if I were to say 6 and 12 they would be clicks from for tight. Brett's are going to be run at 2/4 when he brings out the new motor.
Brett Miller W9 cnc'd heads STR Chassis fabraction
