I have Double adjustables in all four corners separation and rotation have nothing to do with one another
You have caltracs correct.. that turns the front pretty much solid.. the front is moving up which allows the rotation.. if the body didnt lift you would have about zero rotation... but then you wouldnt be applying the pressure on the diff
