Re: Hotchkis TVS, Brakes, and Rear End Install
[Re: MuuMuu101]
#1661444
12/24/14 01:52 AM
12/24/14 01:52 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Yes you can switch spindles and your calipers will be mounted in the rear.
I was really worried 3 years ago when my stock rear mount calipers hit those Hotchkis UCA's. Hotchkis saw the interference first hand. I thought they were going to add that info to assembly instructions.
I just hoped an aftermarket caliper would clear. But I've been looking at Wilwood and DrDiff setups at shows for years and just knew I was hoping a square peg would fit a round hole.
My plan is to run front air ducts with rear mount aftermarket calipers. Running air ducts to the front is much cleaner than the rear. And I don't even think there is room with the shock to get a 3" duct to the rear.
This S*CKS
My friend jokingly asked me, "If you want, we can machine your caliper." I took a look at it and said, "What are you going to do, machine off the entire bleeder?" It was pretty bad. At full droop, the caliper didn't hit the UCA, but they overlapped by an inch or so.
What would be the issue with running a brake duct to the front of the rotor beneath the caliper?
Is there that much room there to do that? Could you take a pic from the inside when you get the rotor on.
Also, a 3" duct will sit very low with the caliper up front. Most likely below the LCA.
What is also bad is if a customer was running a Hotchkis UCA with stock or non Hotchkis aftermarket front sway bar that mounts to the stock sway bar mount on the LCA. Those customers (potential customers) typically run the calipers to the rear. There are 4 combinations of that rear caliper setup:
rear pin calipers 10.75" rotor rear pin calipers 11.75" rotor (I've tested, does not work) rear slider caliper 10.75" rotor rear slider caliper 11.75" rotor
I haven't tested the 3 other combinations. IMHO, it's a higher than 50/50 chance are they will not work.
Entire Thread
MuuMuu101
08/20/14 08:53 AM
Uhcoog1
08/20/14 02:12 PM
MuuMuu101
08/20/14 11:39 PM
Uhcoog1
08/21/14 09:26 PM
MuuMuu101
08/22/14 07:02 AM
MuuMuu101
08/23/14 01:58 AM
goldduster318
08/23/14 02:08 AM
MuuMuu101
08/23/14 02:43 AM
OzHemi
08/23/14 02:15 AM
MuuMuu101
08/23/14 02:42 AM
goldduster318
08/23/14 02:45 AM
goldduster318
08/23/14 02:47 AM
MuuMuu101
08/23/14 03:05 AM
goldduster318
08/23/14 03:08 AM
MuuMuu101
08/23/14 03:18 AM
feets
08/23/14 03:55 PM
MuuMuu101
08/23/14 05:47 PM
MuuMuu101
08/21/14 07:13 AM
RylisPro
08/21/14 07:29 AM
RylisPro
08/20/14 02:24 PM
jcc
08/20/14 03:21 PM
MuuMuu101
08/20/14 11:53 PM
MuuMuu101
08/20/14 11:50 PM
OzHemi
08/20/14 11:57 PM
MuuMuu101
08/21/14 12:03 AM
OzHemi
08/21/14 12:05 AM
OzHemi
08/21/14 12:08 AM
MuuMuu101
08/21/14 12:28 AM
340duster340
08/21/14 03:17 AM
jcc
08/21/14 03:24 AM
MuuMuu101
08/21/14 05:06 AM
72Swinger
08/21/14 05:55 AM
MuuMuu101
08/21/14 07:38 AM
DoctorDiff
08/21/14 09:21 AM
MuuMuu101
08/22/14 07:00 AM
feets
08/20/14 04:39 PM
MuuMuu101
08/20/14 11:57 PM
MuuMuu101
08/28/14 05:57 AM
RylisPro
08/28/14 06:01 AM
MuuMuu101
08/28/14 06:14 AM
RylisPro
08/28/14 06:23 AM
MuuMuu101
08/28/14 06:44 AM
MuuMuu101
08/29/14 06:17 AM
OzHemi
08/29/14 10:42 PM
PHJ426
08/29/14 11:09 PM
MuuMuu101
08/29/14 11:15 PM
72Swinger
08/30/14 12:53 AM
moparpollack
09/02/14 05:28 AM
MuuMuu101
09/02/14 05:39 AM
feets
09/02/14 04:39 PM
340duster340
09/03/14 12:47 AM
MuuMuu101
09/03/14 03:14 AM
feets
09/03/14 05:46 AM
MuuMuu101
09/03/14 07:04 AM
feets
09/03/14 09:09 PM
BigBlockMopar
09/03/14 10:43 PM
Birdturd
09/03/14 11:11 PM
MuuMuu101
09/04/14 02:50 AM
goldduster318
09/04/14 02:58 AM
MuuMuu101
09/04/14 03:09 AM
goldduster318
09/04/14 03:17 AM
MuuMuu101
09/04/14 03:21 AM
MuuMuu101
09/04/14 03:36 AM
MuuMuu101
09/04/14 03:54 AM
goldduster318
09/04/14 04:00 AM
feets
09/04/14 04:11 AM
MuuMuu101
09/04/14 04:28 AM
340duster340
09/06/14 04:17 AM
OzHemi
09/06/14 04:54 AM
MuuMuu101
09/06/14 07:37 AM
MuuMuu101
09/06/14 07:44 AM
MuuMuu101
09/06/14 07:44 AM
MuuMuu101
09/06/14 10:44 PM
goldduster318
09/06/14 10:56 PM
MuuMuu101
09/06/14 10:57 PM
MuuMuu101
09/09/14 02:48 AM
feets
09/09/14 04:10 PM
moparx
09/10/14 03:01 AM
MuuMuu101
09/10/14 04:53 AM
feets
09/10/14 06:50 AM
BigBlockMopar
09/10/14 09:26 AM
OzHemi
09/10/14 05:25 PM
MuuMuu101
09/12/14 04:37 AM
feets
09/12/14 05:07 AM
MuuMuu101
09/12/14 05:18 AM
feets
09/12/14 02:47 PM
MuuMuu101
09/13/14 06:59 AM
feets
09/13/14 03:14 PM
PHJ426
09/13/14 03:54 PM
MuuMuu101
09/13/14 04:48 PM
MuuMuu101
09/13/14 04:47 PM
feets
09/14/14 12:36 AM
moparx
09/14/14 02:11 PM
MuuMuu101
09/14/14 05:35 PM
roadrunninMark
09/14/14 10:15 PM
MuuMuu101
09/15/14 06:08 AM
MuuMuu101
09/19/14 02:03 AM
goldduster318
09/19/14 03:36 AM
MuuMuu101
09/19/14 05:34 AM
goldduster318
09/20/14 12:05 AM
MuuMuu101
09/20/14 12:33 AM
MuuMuu101
09/20/14 12:49 AM
Dan@Hotchkis
09/20/14 01:11 AM
MuuMuu101
09/20/14 01:14 AM
72Swinger
09/20/14 03:21 AM
MuuMuu101
09/23/14 01:33 AM
OzHemi
09/12/14 06:03 PM
MuuMuu101
09/04/14 02:47 AM
PHJ426
08/30/14 01:24 AM
MuuMuu101
08/31/14 05:05 AM
PHJ426
08/31/14 01:57 PM
MuuMuu101
08/31/14 10:13 PM
MuuMuu101
12/20/14 03:09 AM
RylisPro
12/20/14 03:32 AM
72Swinger
12/20/14 04:13 AM
Supercuda
12/20/14 04:35 AM
Dan@Hotchkis
12/20/14 04:44 AM
MuuMuu101
12/21/14 07:21 PM
autoxcuda
12/20/14 05:01 AM
340duster340
12/20/14 05:20 AM
MuuMuu101
12/20/14 09:44 AM
goldduster318
12/20/14 04:15 PM
prrc
12/21/14 11:14 PM
autoxcuda
12/22/14 12:55 AM
prrc
12/22/14 05:01 AM
MuuMuu101
12/22/14 05:22 AM
goldduster318
12/23/14 06:26 PM
MuuMuu101
12/24/14 03:00 AM
MuuMuu101
12/24/14 03:40 AM
goldduster318
12/24/14 04:08 AM
MuuMuu101
12/24/14 04:58 AM
autoxcuda
12/24/14 05:24 AM
MuuMuu101
12/24/14 05:34 AM
autoxcuda
12/24/14 05:52 AM
MuuMuu101
12/24/14 06:29 AM
72Swinger
12/24/14 06:46 AM
autoxcuda
12/24/14 07:14 AM
Dan@Hotchkis
12/24/14 07:11 AM
DoctorDiff
12/24/14 07:13 AM
MuuMuu101
12/24/14 07:15 AM
feets
12/28/14 08:01 AM
feets
12/28/14 08:02 AM
Uhcoog1
12/30/14 09:47 PM
feets
12/31/14 04:41 AM
dangina
12/31/14 05:11 AM
Consulier
12/31/14 05:06 PM
72Swinger
12/31/14 07:13 PM
BigBlockMopar
12/31/14 10:48 PM
Uhcoog1
12/31/14 06:01 AM
BergmanAutoCraft
12/31/14 06:08 PM
autoxcuda
12/28/14 09:10 AM
feets
12/28/14 04:52 PM
autoxcuda
12/28/14 10:01 PM
340duster340
12/28/14 11:16 PM
autoxcuda
12/29/14 03:44 AM
feets
12/29/14 02:19 AM
autoxcuda
12/29/14 04:05 AM
72Swinger
12/29/14 05:28 AM
autoxcuda
12/29/14 07:19 AM
72Swinger
12/29/14 07:57 AM
autoxcuda
12/29/14 08:07 AM
MuuMuu101
12/29/14 08:15 AM
autoxcuda
12/29/14 08:19 AM
72Swinger
12/29/14 08:48 AM
MuuMuu101
12/29/14 08:53 AM
DoctorDiff
12/30/14 07:57 AM
autoxcuda
12/30/14 08:41 AM
DoctorDiff
12/30/14 02:14 PM
72Swinger
12/30/14 04:49 PM
Supercuda
12/30/14 06:58 PM
MuuMuu101
12/31/14 03:40 AM
MuuMuu101
12/31/14 03:43 AM
feets
01/01/15 04:21 AM
MuuMuu101
01/01/15 04:24 AM
moparx
01/01/15 01:38 PM
feets
01/01/15 05:04 PM
MuuMuu101
12/21/14 07:24 PM
MuuMuu101
02/01/15 04:43 AM
MuuMuu101
02/01/15 04:45 AM
4speeds4me
02/01/15 05:35 AM
MuuMuu101
02/01/15 05:49 AM
MuuMuu101
02/01/15 05:52 AM
Brian
02/01/15 06:15 AM
MuuMuu101
02/01/15 06:22 AM
goldduster318
02/01/15 03:21 PM
Mopar Mitch
02/02/15 07:10 PM
MuuMuu101
02/03/15 12:47 AM
Tomswheels
02/01/15 06:02 AM
MuuMuu101
02/01/15 06:13 AM
MuuMuu101
02/15/15 06:42 AM
MuuMuu101
02/15/15 06:43 AM
MuuMuu101
02/15/15 06:43 AM
MuuMuu101
02/15/15 06:44 AM
MuuMuu101
02/15/15 06:44 AM
MuuMuu101
02/15/15 06:45 AM
4speeds4me
02/15/15 07:44 AM
RylisPro
02/15/15 08:35 AM
72Swinger
02/15/15 10:55 AM
Uhcoog1
02/15/15 03:05 PM
goldduster318
02/15/15 04:55 PM
MuuMuu101
02/15/15 06:48 PM
moparpollack
02/15/15 06:53 PM
MuuMuu101
03/13/15 06:33 AM
4speeds4me
03/13/15 07:59 AM
MuuMuu101
03/14/15 04:39 AM
