Why can't you run aftermarket rear mounted calipers with Hochkis UPC?
I don't know anyone that that's ran rear mount aftermarket. Muumuu is on uncharted ground.
But I have tried rear pin mounted caliper with 11.75" factory rotors and it did not work. It's because the rear leg of the Hotckiss UCA takes a rearward curve where most others are straight or slightly curved.
