Re: Hotchkis TVS, Brakes, and Rear End Install
[Re: MuuMuu101]
#1661368
09/03/14 05:09 PM
09/03/14 05:09 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The rear diff, springs, and brakes are easy. You can knock that out in an hour if you know what you're doing and have all the parts.
The front end is more complicated due to having more fiddly bits and dealing with alignment. A seasoned pro can knock one out quickly but someone just starting out will likely take a full day once everything is on hand.
One thing I will suggest is a quick and dirty alignment. Once the tires look like they are more or less straight up and down you need to look at toe.
Lift each front tire off the ground. Grab a screwdriver and hold it steady. Spin the tire and let the pointy tip of the screwdriver drag along the tire somewhere in the middle of the tread. Done right it will scribe a line around the tire.
Do this on both sides.
Put the car on the ground and bounce the suspension a bit to settle things.
Slide a tape measure under the car to your friend on the other side.
Measure the distance between the marks on the tires in the front and rear. Adjust your tie rods until the measurements are the same.
*POOF*
You just did a quickie alignment good enough to get you to an alignment shop without trashing your new tires.
Note that the marks do not have to be on the same portion of the tread for left and right. As long as you scribe a perfect ring and don't wobble about you're fine.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
Entire Thread
MuuMuu101
08/20/14 08:53 AM
Uhcoog1
08/20/14 02:12 PM
MuuMuu101
08/20/14 11:39 PM
Uhcoog1
08/21/14 09:26 PM
MuuMuu101
08/22/14 07:02 AM
MuuMuu101
08/23/14 01:58 AM
goldduster318
08/23/14 02:08 AM
MuuMuu101
08/23/14 02:43 AM
OzHemi
08/23/14 02:15 AM
MuuMuu101
08/23/14 02:42 AM
goldduster318
08/23/14 02:45 AM
goldduster318
08/23/14 02:47 AM
MuuMuu101
08/23/14 03:05 AM
goldduster318
08/23/14 03:08 AM
MuuMuu101
08/23/14 03:18 AM
feets
08/23/14 03:55 PM
MuuMuu101
08/23/14 05:47 PM
MuuMuu101
08/21/14 07:13 AM
RylisPro
08/21/14 07:29 AM
RylisPro
08/20/14 02:24 PM
jcc
08/20/14 03:21 PM
MuuMuu101
08/20/14 11:53 PM
MuuMuu101
08/20/14 11:50 PM
OzHemi
08/20/14 11:57 PM
MuuMuu101
08/21/14 12:03 AM
OzHemi
08/21/14 12:05 AM
OzHemi
08/21/14 12:08 AM
MuuMuu101
08/21/14 12:28 AM
340duster340
08/21/14 03:17 AM
jcc
08/21/14 03:24 AM
MuuMuu101
08/21/14 05:06 AM
72Swinger
08/21/14 05:55 AM
MuuMuu101
08/21/14 07:38 AM
DoctorDiff
08/21/14 09:21 AM
MuuMuu101
08/22/14 07:00 AM
feets
08/20/14 04:39 PM
MuuMuu101
08/20/14 11:57 PM
MuuMuu101
08/28/14 05:57 AM
RylisPro
08/28/14 06:01 AM
MuuMuu101
08/28/14 06:14 AM
RylisPro
08/28/14 06:23 AM
MuuMuu101
08/28/14 06:44 AM
MuuMuu101
08/29/14 06:17 AM
OzHemi
08/29/14 10:42 PM
PHJ426
08/29/14 11:09 PM
MuuMuu101
08/29/14 11:15 PM
72Swinger
08/30/14 12:53 AM
moparpollack
09/02/14 05:28 AM
MuuMuu101
09/02/14 05:39 AM
feets
09/02/14 04:39 PM
340duster340
09/03/14 12:47 AM
MuuMuu101
09/03/14 03:14 AM
feets
09/03/14 05:46 AM
MuuMuu101
09/03/14 07:04 AM
feets
09/03/14 09:09 PM
BigBlockMopar
09/03/14 10:43 PM
Birdturd
09/03/14 11:11 PM
MuuMuu101
09/04/14 02:50 AM
goldduster318
09/04/14 02:58 AM
MuuMuu101
09/04/14 03:09 AM
goldduster318
09/04/14 03:17 AM
MuuMuu101
09/04/14 03:21 AM
MuuMuu101
09/04/14 03:36 AM
MuuMuu101
09/04/14 03:54 AM
goldduster318
09/04/14 04:00 AM
feets
09/04/14 04:11 AM
MuuMuu101
09/04/14 04:28 AM
340duster340
09/06/14 04:17 AM
OzHemi
09/06/14 04:54 AM
MuuMuu101
09/06/14 07:37 AM
MuuMuu101
09/06/14 07:44 AM
MuuMuu101
09/06/14 07:44 AM
MuuMuu101
09/06/14 10:44 PM
goldduster318
09/06/14 10:56 PM
MuuMuu101
09/06/14 10:57 PM
MuuMuu101
09/09/14 02:48 AM
feets
09/09/14 04:10 PM
moparx
09/10/14 03:01 AM
MuuMuu101
09/10/14 04:53 AM
feets
09/10/14 06:50 AM
BigBlockMopar
09/10/14 09:26 AM
OzHemi
09/10/14 05:25 PM
MuuMuu101
09/12/14 04:37 AM
feets
09/12/14 05:07 AM
MuuMuu101
09/12/14 05:18 AM
feets
09/12/14 02:47 PM
MuuMuu101
09/13/14 06:59 AM
feets
09/13/14 03:14 PM
PHJ426
09/13/14 03:54 PM
MuuMuu101
09/13/14 04:48 PM
MuuMuu101
09/13/14 04:47 PM
feets
09/14/14 12:36 AM
moparx
09/14/14 02:11 PM
MuuMuu101
09/14/14 05:35 PM
roadrunninMark
09/14/14 10:15 PM
MuuMuu101
09/15/14 06:08 AM
MuuMuu101
09/19/14 02:03 AM
goldduster318
09/19/14 03:36 AM
MuuMuu101
09/19/14 05:34 AM
goldduster318
09/20/14 12:05 AM
MuuMuu101
09/20/14 12:33 AM
MuuMuu101
09/20/14 12:49 AM
Dan@Hotchkis
09/20/14 01:11 AM
MuuMuu101
09/20/14 01:14 AM
72Swinger
09/20/14 03:21 AM
MuuMuu101
09/23/14 01:33 AM
OzHemi
09/12/14 06:03 PM
MuuMuu101
09/04/14 02:47 AM
PHJ426
08/30/14 01:24 AM
MuuMuu101
08/31/14 05:05 AM
PHJ426
08/31/14 01:57 PM
MuuMuu101
08/31/14 10:13 PM
MuuMuu101
12/20/14 03:09 AM
RylisPro
12/20/14 03:32 AM
72Swinger
12/20/14 04:13 AM
Supercuda
12/20/14 04:35 AM
Dan@Hotchkis
12/20/14 04:44 AM
MuuMuu101
12/21/14 07:21 PM
autoxcuda
12/20/14 05:01 AM
340duster340
12/20/14 05:20 AM
MuuMuu101
12/20/14 09:44 AM
goldduster318
12/20/14 04:15 PM
prrc
12/21/14 11:14 PM
autoxcuda
12/22/14 12:55 AM
prrc
12/22/14 05:01 AM
MuuMuu101
12/22/14 05:22 AM
goldduster318
12/23/14 06:26 PM
MuuMuu101
12/24/14 03:00 AM
MuuMuu101
12/24/14 03:40 AM
goldduster318
12/24/14 04:08 AM
MuuMuu101
12/24/14 04:58 AM
autoxcuda
12/24/14 05:24 AM
MuuMuu101
12/24/14 05:34 AM
autoxcuda
12/24/14 05:52 AM
MuuMuu101
12/24/14 06:29 AM
72Swinger
12/24/14 06:46 AM
autoxcuda
12/24/14 07:14 AM
Dan@Hotchkis
12/24/14 07:11 AM
DoctorDiff
12/24/14 07:13 AM
MuuMuu101
12/24/14 07:15 AM
feets
12/28/14 08:01 AM
feets
12/28/14 08:02 AM
Uhcoog1
12/30/14 09:47 PM
feets
12/31/14 04:41 AM
dangina
12/31/14 05:11 AM
Consulier
12/31/14 05:06 PM
72Swinger
12/31/14 07:13 PM
BigBlockMopar
12/31/14 10:48 PM
Uhcoog1
12/31/14 06:01 AM
BergmanAutoCraft
12/31/14 06:08 PM
autoxcuda
12/28/14 09:10 AM
feets
12/28/14 04:52 PM
autoxcuda
12/28/14 10:01 PM
340duster340
12/28/14 11:16 PM
autoxcuda
12/29/14 03:44 AM
feets
12/29/14 02:19 AM
autoxcuda
12/29/14 04:05 AM
72Swinger
12/29/14 05:28 AM
autoxcuda
12/29/14 07:19 AM
72Swinger
12/29/14 07:57 AM
autoxcuda
12/29/14 08:07 AM
MuuMuu101
12/29/14 08:15 AM
autoxcuda
12/29/14 08:19 AM
72Swinger
12/29/14 08:48 AM
MuuMuu101
12/29/14 08:53 AM
DoctorDiff
12/30/14 07:57 AM
autoxcuda
12/30/14 08:41 AM
DoctorDiff
12/30/14 02:14 PM
72Swinger
12/30/14 04:49 PM
Supercuda
12/30/14 06:58 PM
MuuMuu101
12/31/14 03:40 AM
MuuMuu101
12/31/14 03:43 AM
feets
01/01/15 04:21 AM
MuuMuu101
01/01/15 04:24 AM
moparx
01/01/15 01:38 PM
feets
01/01/15 05:04 PM
MuuMuu101
12/21/14 07:24 PM
MuuMuu101
02/01/15 04:43 AM
MuuMuu101
02/01/15 04:45 AM
4speeds4me
02/01/15 05:35 AM
MuuMuu101
02/01/15 05:49 AM
MuuMuu101
02/01/15 05:52 AM
Brian
02/01/15 06:15 AM
MuuMuu101
02/01/15 06:22 AM
goldduster318
02/01/15 03:21 PM
Mopar Mitch
02/02/15 07:10 PM
MuuMuu101
02/03/15 12:47 AM
Tomswheels
02/01/15 06:02 AM
MuuMuu101
02/01/15 06:13 AM
MuuMuu101
02/15/15 06:42 AM
MuuMuu101
02/15/15 06:43 AM
MuuMuu101
02/15/15 06:43 AM
MuuMuu101
02/15/15 06:44 AM
MuuMuu101
02/15/15 06:44 AM
MuuMuu101
02/15/15 06:45 AM
4speeds4me
02/15/15 07:44 AM
RylisPro
02/15/15 08:35 AM
72Swinger
02/15/15 10:55 AM
Uhcoog1
02/15/15 03:05 PM
goldduster318
02/15/15 04:55 PM
MuuMuu101
02/15/15 06:48 PM
moparpollack
02/15/15 06:53 PM
MuuMuu101
03/13/15 06:33 AM
4speeds4me
03/13/15 07:59 AM
MuuMuu101
03/14/15 04:39 AM
