Don't let it stall. Get that car back on the ground ASAP.
agreed 4 jack stands = kiss of death for many projects
I know... I know... The added pressure doesn't help. I'm still a little scarred from the last time I did the brakes. The plans for Friday are installing the 8 3/4 (w/ leaf springs of course) and getting a majority of the lines figured out and redone.
Leave the rear end alone. That's the easy bit.
Get the hard stuff out of the way now while you have a bit of momentum.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
