Looking at your pictures, you still have a fair amount of body roll. This allows a couple of different approaches to improve.
The most direct improvement would be to shorten the upper control arm to allow more dynamic camber to come in with the roll. This is tough to do with the OEM control arms but could be accomplished with a more adjustable unit like SPC.
I must be missing something but unless you relocate the inner pivot to account for a shorter UCA you will increase the static camber as well, not sure that's a good idea.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
