Re: Tire wear, Additional camber, and tire pressures
[Re: Uhcoog1]
#1566078
01/22/14 02:40 AM
01/22/14 02:40 AM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
Thanks for the heads up! I went ahead and flipped the more worn set and put them on the rear. Will probably give up some traction with the 'wrong' compound facing out, but my set up can stand to lose a little traction in the rear and still be fine.
38/34 for super sports- is that cold or hot?
Oh yeah- my tire guy agreed with you- didn't think the wear was that abnormal. Shoot, the inner to outer main tread wear was only 2/32 off (7/32 vs 5/32). He indicated wearing through the side block wasn't a concern to him.
That's my cold pressure. As your tires wear, you should notice they don't wear out quite as quickly, the tread blocks are more stable with less than 1/2 instead of full tread...
Entire Thread
Uhcoog1
01/20/14 10:30 PM
Uhcoog1
01/20/14 10:33 PM
72Swinger
01/21/14 01:09 AM
Tomswheels
01/21/14 08:12 AM
Uhcoog1
01/21/14 04:01 PM
autoxcuda
01/21/14 06:55 PM
Uhcoog1
01/21/14 07:47 PM
Uhcoog1
01/21/14 08:18 PM
Dan@Hotchkis
01/22/14 01:53 AM
Tomswheels
01/22/14 06:40 AM
Uhcoog1
01/23/14 06:59 PM
Rapom65
01/24/14 12:32 AM
Dan@Hotchkis
01/24/14 03:43 AM
Uhcoog1
01/24/14 05:01 AM
72Swinger
01/30/14 07:23 PM
Dan@Hotchkis
01/21/14 05:37 AM
autoxcuda
01/21/14 06:06 AM
Uhcoog1
01/21/14 06:15 AM
amxautox
01/21/14 06:18 AM
Dan@Hotchkis
01/21/14 06:20 AM
Uhcoog1
01/21/14 07:02 AM
autoxcuda
01/21/14 07:07 AM
TC@HP2
01/30/14 07:16 PM
Uhcoog1
01/30/14 09:58 PM
Consulier
01/30/14 10:08 PM
72Swinger
01/30/14 10:16 PM
Uhcoog1
01/31/14 12:58 AM
72Swinger
01/31/14 01:39 AM
Consulier
01/31/14 05:03 PM
72Swinger
01/31/14 06:10 PM
Tomswheels
01/31/14 06:37 AM
Uhcoog1
01/31/14 03:21 PM
Tomswheels
02/01/14 08:03 AM
Uhcoog1
02/01/14 09:54 AM
Trojmn
02/01/14 10:33 AM
Uhcoog1
02/01/14 04:50 PM
Trojmn
01/31/14 02:10 AM
Trojmn
01/31/14 07:29 AM
Consulier
01/31/14 05:02 PM
Supercuda
01/31/14 12:34 AM
TC@HP2
02/02/14 08:24 PM
