I have an 81 Cordoba, teetering on whether to sell it or mess with it some. 1 barrel slanty, not really peppy and I believe the carb's the issue. Runs fine, but has hot start issues also
"some" have said the Carter is inferior to the Holley 1 barrel. Any insight on that?
Mine does the ~starts easy, but when it's hot, loads up bad and you have to "clean" it out when restarting~ issue.
