Quote: I have an intake and kickdown if you decide to go with a 2bbl
and if you buy his two barrel ill toss you a little cash for youe one barrel setup
i had a long bed dodge with a 3 speed stick electric fan recurved dist and not much else and it woild smoke really wide tires!
is yours a 727?if so its eating lots of power. got smog pump? got cat vonv? 80s had smaller hydr cams iirc
the fun thing about slants is that you feel evrything you touch.2bbl swap nets about 10% power improvement!ever put a junkyard intake on a smallblock and get a 40 horsepower improvement?a slant six will teach you discipline with not throwing power in the trash.with a slant six a person learns what a hundred hp really is and what can be done with it.
