How are you sintalling teh u joints? Are you seating them against the clips after installing the clips? It's driveshaft. Definately. If you moved it up and fdowna couple degrees (pinion angle) what is is currently set at? You are positive you're measuring it properly?
Well, art is art, isn't it? Still, on the other hand, water is water! And east is east and west is west and if you take cranberries and stew them like applesauce they taste much more like prunes than rhubarb does. Now, uh... Now you tell me what you know.
