Quote: the only other part that i didnt change was the flex plate. it is a b&m externally balanced pc. i didnt see any cracks and it didnt look to be bent. the converter holes lined up perfect also
Any chance it lost a balance weight?
They don't add weight to them , they remove the required amount of weight 180* off from where you need to add the weight to get the desired result .
