Quote: I'm thinking you have hit it right on Mike..
If he has changed gear ratios, but the vibration stays at 80mph, than it should be easier to narrow it down..
Chris..
when i put the 3.23's in, the vibes were at about 110 mph, it just moved farther away
This all relates back to a rpm, do you know what the rpm's were for the 110 speed and the rpm's for the 80 speed, does it corrilate to the difference in gear ratio where the d-shaft is turning the same rpm?
i cant remeber the rpms with the 3.23's , i'll get a better number with the 4.30s next time i take it out. but since i still have the vibes with both the 430s and the 323s, wouldnt that eliminate the gears?
