Quote: i think the rpms are around 5200 at 80, this is with 4.30s
That can't be right unless your converter is slipping real bad or your tires are about 20" tall. Should be well over 100 MPH at 5200 rpm.
Quote: the only other part that i didnt change was the flex plate. it is a b&m externally balanced pc. i didnt see any cracks and it didnt look to be bent. the converter holes lined up perfect also
