I used the Harbor Freight stretcher/shrinker to form a new end for both sides and butt-welded them in to the dutchman panel. It was a little intimidating at first bacause of the compound curves, but it really was pretty easy. It only took about an hour to do each side and the fit is near perfect. I say near perfect because I don't believe anything can be truly perfect on this sort of thing.
