The window channel was rusted pretty bad in the bottom corners and in the trim screw indents. I can't seem to find the pics of the corners still rusty but try to imagine rust and you'll get the picture. Here's the trim screw areas. I made little pieces and butt welded them in. They aren't exactly the same shape but they are the right depth and angle. Originals were sort of rounded out like a bowl.
