I wrote the article you referred to in
www.moparmax.com and the initial one in
www.dragracingonline.com as well.
The fixture tool came with mine and I am surprised Jesel missed it on yours. Two years, ZERO problems.
We set the final plate height pretty much like you did and ended up with a very similar rocker tip print on the valve. I would recommend the offset intake roller from Comp Cams to straighten the pushrod. (We send the rollers in at 150 runs to prevent a disaster, only $165.00 for rebuild and peasce of mind.
We will be doing more and more Mopar Tech now that our newest magazine is getting over 3500 readers per day, check it our when you get a chance-
www.MoparMax.comGreat series of photos and tech on your install I just read here on Moparts, nicely done.
Jok Nicholson
dragsterboy@mchsi.com
