I mocked up a standard offset intake by using two of the exhaust rocker arms. As far as I can tell by looking at this and taking a bunch of measurements this setup will work just fine. I'll either need new shafts from Jesel or a some spacers to put on the existing shafts to take up the extra clearance. In this picture my mockup using two exhaust rockers is on the right. The setup on the left is the .750 offset intake that comes in the 440-1 kit.
