why not get a stock flywheel redrilled for the smaller clutch? basically all your adding is the 6 holes that bolt on the clutch if i'm understanding this correctly. if its too hard to drill, the flywheel can be EDM, this may not be a really cheap option but with minimal effort you could try it.
Superior Design Concepts 2574 Elliott Dr Troy MI 48083 jerry@sdconcepts.com www.sdconcepts.com Facebook page: Superior Design Concepts www.bcrproducts.com
