The new gauges are the Stewart Warner Green Line's. I have them in my 70 and they work great and are easy to read. The Switch is a separate switch for the electric fuel pump. I have it wired key hot so he can't accidentally leave it on but wanted to be able to shut it off if I needed to... Once I get the hood back on I'll still need to sort out an air cleaner that stays under the hood as he does not want to cut anything. In looking at the pics I may also lower the front ride height a small amount... I also ordered a factory Gold Duster side stripe kit in Matte Black to put back on it...
