The plastic trim on the body is the only thing I will be removing from the exterior. I picked up a set of Wilwood disc brakes for all 4 corners and am re-using a 65 B Body 8 3/4 I had laying around along with a set of 4.56 gears. Plan is to use Cal Tracs rear suspension and tie the frame together with the kit from US Cartool. It got backed into the garage today to begin the transformation after removing the stinking gas tank and lines outside a month or so ago.
