We had to tap the two holes in the water pump where the bypass hose and heater hoses were located. Lower control arms with new bushings and new strut rod bushings installed... Alternator brackets and spacers worked out... Lokar flexible transmission dipstick used rather than stock... MSD distributor in using the black advance pill along with one silver and one blue spring rather than the factory "barn door" springs. New 45* Taylor wires and plugs and its ready to install from the bottom...
