There is 4 new wheels and tires on it... 275-60-15 M/T ET Streets... Need to stop by tonight and get a few pics... I also need to find some time to stop down and get the under dash wiring all hooked up for the MSD and the relocated battery... I'll finish the steering column when I can get the motor in from the bottom with the K frame and put everything together once...
