Emissions are way down with my 20% mix. remember my NY Gas already has 10% methanol wich hurts performance as is but helps emissions from 100% gas. and My engine is Highly matained as far as clean fuel sustem and so on - do you pull all your fuel sustem parts and flow test them with calibrated flow meter? and your injectors and test flow @ pressures with a pulse generator, and test spark system for actual voltage and current at the plug gap in Jules of energy???? Ha HA. just cause I beat the C --- out of it doesent mean I dont follow scientific method accepted by ASTM and way more strignent test case control that you may think.. I do high purity chemical engineering for 20 years and am not your usual joe Mechanic . I A MAD Scientist and Mopar ADDICT by nature and profession. you nay sayers can say all ya want while I and some other believers bring the future to fruituition in fuel improvement and keep performance as a priority unlike gas companys which want to sell more gas not less. either get on board cause the train has left the station. (playing) Ozzies "Crazy Train"
