Hemigreg--I believe everything you say because I know Nothing about fuels .Sad because I am a auto tech.I see you're running your fuel concoctions in an 88 Lincoln ,If it does blow the heads off you can buy another car for 1000 bucks Not sure I would give all the advice to normal folks to run these in there 6 yr financed late model vehicles to get better gas mileage and power.Blowing the heads off under warranty would be a problem and somebody would figure out what happened.
However ,since I am adventuristic what is the bottom line in plain english -2 liters per 20 gals?
