Where can 99.99999% acetone be purchased?
Semiconductor grade, someone's been pilfering from work.
It ain't cheap if you buy it, in fact odds are if you figured the cost of semiconductor grade acetone into to your fuel pricing it will cost more money even IF and I say IF it increases your mileage. That stuff isn't cheap.
you cant cept for 60 bucks per gallon ans same for 5 999999 Hydroges 1k $ PER CULINDER.
i WELD A THERMOCOUPLE O RACH OUTLRT PORT SND SET UP FLOW TO MAX COOLNESS OF MIXTURE THST MEAND MAX QUENCH AND MAX POWER THEN ADJUST DISTRIBUTION WITH TINY OIL URNRT NOZZLES WITH GATE VALVES THEN PEAK OUT YUOR MIXTYRE AT FULL LOAD RPM AND BE SURE TO BAKALCE ALL Y THERMOCOUPLES. THOSE oS SENSORS ARE JUNK EVER SEE ONE ON A GOOD DUYN>>>> RUN.
GO MAX OF 10% TO COUJTER ACT THE 10 % METHANOL.
THIS WEEL ITS GOING TO BE 40 DEGREES TIMING, NITRO,vp111, ACRTONE AND 20% PURE OXYGER.
OFF TO THE MOON BABY.
What did you say?
