Quote: Dart-sport Satellite,what brand of gasoline did your friends use?? which worked best?
Talked to him today, he uses whatever gas is convenient. When he first started testing the acetone mix, he went around to a bunch of stations to find which gas gave him the best mileage for HIS car. After he found this out, he proceded to test how much acetone would give him the best improvement. He started at 1/4 oz. per 10 gals. and worked up to where the mileage dropped off, then back down to where the mileage was best. He's using 2 and 1/4 oz. per 10 gallons, and now buys his gas wherever is convenient.
