Quote: 14.5 to 1, 4.90's in the 1/8 good? Run it right out of the pump. I do run methanol and gas to test stuff on occasion. What do you want to know?
just curious how much difference is there between the tune on a gas vs E85? I bought a quickfuel 950 E85 carb a couple of years ago. I also bought the FAST E85 wide band. it would tell me one thing but the car another. if that makes sense.
The wideband is just a tool, you have to listen to what the engine wants. As far as tune difference E85 seems to like less emulsion, and smaller holes in the emulsion channel. Passages need to be larger than gas, depending on the carb size as to how large.
Mark Whitener [url=www.racingfuelsystems.com[/url]
