Quote: I totally understand the rational for not using the tamper resistant material on the reproduction labels, appreciate the reply.
MikeR
Hi Mike, I just wanted to clarify that the material we use for the reproduction Chrysler VIN decals, IS in fact a tamper resistant product. It does not remove in the same fashion as the originals however. We chose the variant form of material because it doesn't destroy the entire foundation layer when it is removed. The base layer will remain but the face of the printed surface will separate away from the clear overlay if it has been firmly pressed into place. It allows for (some) positioning correction during the initial application phase. Sorry for the confusion.
