The plugs are metal and hold the panel down on the ends. All A-bodys use them, E-bodys have the clip like a door panel under the tray. Are there 2 or 4 on that car? You can see them from inside the trunk.
Is the car p/s? If so is there a 90 deg. fitting on the steering box like a hemi car with p/s?
