Quote: Dave I have a question on the horns.The horn you have the photo of, appears to have a bolt securing the horn to the bracket.Thus allowing the horn to be pivoted about the bracket.Do you know if this style was a replacment horn,or to what cars the solid mount was original to?
As far as I know, most early 70's original horns had this type of configuration. Of all the ones I have worked with the bracket was never solidly attached to the horn but had the ability to move bidirectional a click (or raised spot) at a time.
