Who ever designed Wilwood disc brakes didn't take into account the space once occupied by the original drum brake backing plates.
Wilwood backing plates double as wheel bearing retainers. This positions the axles too far inward. You must run a 1/8" spacer between the backing plate and the housing end, otherwise the bearings will self destruct due to excessive preloading of the axles against the thrust block.
