Quote: Go with the caltracs and don't look back....plenty of guys in the 9s running them...And you can install them in the driveway with a hand fiull of tools.
Yes, but once installed, I HIGHLY recommend you weld straps (gussets) from the front and back of the spring perches to the top of the axle housing, as all that extra torque can damage the axle tubes - Been there-done that.
