Quote: I haven't seen you post in awhile, have you had you car on the road with the 1.22" TB, and how did you like like it? I am a big believer in macho TB's, anything under 1" is for girls, but a 1.22" on the street makes me pause, so what do you think? MoparKid has a set, but not yet driving, I have a set on the shelf, but you guys go first
What body and motor are you planning on running?
A 71 big block B-body is one heavy car. A 68 Road Runner is pretty beefy too.
Also tire compliance keeping some thickess in the sidewall helps. This is why I'm not real thrilled with 18" rims. You end up having to get a smaller sidewall than you would have with 17" rims.
Good shocks are more and more important as you increase to larger and larger 1" plus sized T-bars.
