Wonder if they use the 'SR' INTAKE port with a lower exhaust? Randy has the cnc '345' -1 Indys with 2.25" Intakes on his jalopy with a SMALL/gentle cam you spec'd. 540"
The EZ intake ports are not the same as the SR either. In ootb form, they’re better……..and easier to get into the 340+ range.
Hard to believe I sold that cam to your friend 15 years ago!!
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
